On the later models with the "pairs system" they have dowels and O rings .tony.mon wrote:?darkember wrote:Another point that can be missed is the small o ring on the dowel under the cam cover if that gets missed the same effect will happen
Dowel under the cam cover?
O ring?
Pics please, I can't recall ever seeing these.
The cam cover is located on the machined flat head mating surface with only the large rubber seal with four half moon sections moulded into it.
It's possible to have one of those misaligned, oil will leak out if so, but there's no dowel or O ring, iirc.
Dont forget the washers!!
Re: Dont forget the washers!!
Thank you, I stand corrected.
I've worked on loads of those and never noticed the difference....
I suppose if the dowel and o ring stays where it is there's no need to do anything about it, especially if it stays with the cam cover on disassembly.
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Thanks Lloydie forgot to add it refers to F2 models and later ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
