Ok, so I've been reading this thread and the only thing my little mind can't work its way around is the 180* out business.
Yes, I can see how it could be out if someone has miffed the cams about but I can't see for the life of me how it would still be ride-able at 180* out... That to me would imply you're getting ignition at (around) BDC (don't actually know ignition timing on the VTR
) and therefore only firing on one!
To be able to ride at 180* out, for me, goes against all logic of a four stroke cycle.
Please, someone explain to me how this can be 'masked over' with fueling etc, I'm genuinely struggling. I mean, I've had mine only firing on one (dead plug) and the thing didn't sound right (one of them 'there's some crap in the carbs which I'll blow out' sounds) and barely moved (lumpy not the word) - I couldn't make it out of my (small) street without having to turn around and get the car instead.
I'm not trying to challenge anyone's voice of experience but instead learn from it and better my own understanding. But to me, it just does not sound logical. Even theoretically it shouldn't work as at 180* out, there's minimal compression within the chamber and if there is ignition at or near BDC, the piston will have hell of a lot more work to do to get to TDC which it HAS to do... Or are we saying that the bike is basically a 500 single whilst these problems are arising? But even then, it would only tick over at half RPM (or at least, less than what it should be).
Personally, if the problem is only between 6,500 and 7,500 revs and clears after that, I'd start with the simple things, i.e. Air intake (no obstruction within the venturi for example) and fueling. Assuming the exhausts are standard, ensure there's no obstructions but if not standard, consider the difference in lengths as that can play a part etc etc, blah blah blah.
But again, please would someone explain the 180* out and still running and ride-able scenario?
I'm not death to power tools... If it breaks, it's obviously NOT a power tool!!!
