Fazer Rebuild
BigVeeGrin
Re: Fazer Rebuild
Post by BigVeeGrin »
Magnificent Carl. :thumbup: :clap:
Re: Fazer Rebuild
Just waiting on my polish and wax materials to turn up now. Should be here in a couple of days. Then I can get the paintwork protected and add some more shine. I want to blacken the vinyl seat as it's got a bit sun faded. Havant worked out what's the best product to use for that yet.
BigVeeGrin
Re: Fazer Rebuild
cybercarl wrote:Just waiting on my polish and wax materials to turn up now. Should be here in a couple of days. Then I can get the paintwork protected and add some more shine. I want to blacken the vinyl seat as it's got a bit sun faded. Havant worked out what's the best product to use for that yet.
sh1t - that's clever. Isn't that down Geo's way? :wink:
Re: Fazer Rebuild
Spotted that but thought it was too cruel, like shooting Bambie in the face!! Trust you too stoop so low Andrew. :lol:
Re: Fazer Rebuild
:roll: :roll: :p
scott02464
Re: Fazer Rebuild
Post by scott02464 »
Very nice Carl, the pics are well worth the wait ;-) :lol:
It looks like its been done in a professional spray shop mate, good effort dude
Re: Fazer Rebuild
My crash bungs are almost as big as your tank. :lol: :lol:
Yes it was a slow process and long wait. I'm looking forward to getting it running now and I still have no patience.
mattster
Re: Fazer Rebuild
Post by mattster »
Carl - as loads of folks have said, it looks like you've done a cracking job with the paint there!
My missus has a Fazer too - I had to respray her front fairing after a wee spill during the summer, but my handiwork is no where near as good!
I could be interested in the lower fairing you have for it... can you stick up a picture? Her's is the facelifted (2003) model, but I don't think that changed much apart from the headlights?
Cheers,
Matt
Xenocide
Re: Fazer Rebuild
Post by Xenocide »
Have a go at tricking you charger - plug the fazer + another battery in at once, the voltage from the good battery will trick it into applying charge, unplug working battery , sorted.
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Re: Fazer Rebuild
I will take some pics tomorrow for you if you like. I don't know what brand it is. They do have the holes cut out for the crash bungs though which I have on my bike.
Top tip, I shall have to remember that one. I may try it out of curiosity but I have a new battery on the way. :(
Xenocide
Re: Fazer Rebuild
Post by Xenocide »
It works for knackered electric drill batteries.
(obviously electric drills, it's not going to be steam powered is it :/ )
'94 KTM LC4 400e
Re: Fazer Rebuild
My battery turned up and I got the bike started. Engine has a bit off top end rattle, either cam tensioner needs to adjust itself a notch (I believe it's got grooves and works like a ratchet type thing) or my valves need some adjustment. I may be able to get the tensioner to tighten a notch by giving the bike a thrashing under high revs or put it in gear and rock the bike backwards, otherwise it should tighten on it's own accord after a few hundred miles. We'll see.
I have not noticed if the rattle goes away once warmed up as I have not let the bike run long enough. Apart from that it all sounds healthy.
I also have a slight oil leak coming from between the oil filter cooler take off and the block.
The take off for the oil cooler is behind the oil filter! So it looks like I am going to have to drain the oil, whip the exhaust off, remove the oil filter and remove the filter cooler.
It has a rubber O ring but I will have to put some liquid gasket seal on as well. Doh.
And the funny thing is I had a dream about that about a week ago and was wondering if I had torqued up the bolt that holds it on. I didn't bother checking before filling with oil and putting a new filter on as I was positive I had tightened it up. :roll:
So just a few teething problems to resolve and it will be good to go. :thumbup:
Re: Fazer Rebuild
cybercarl wrote: And the funny thing is I had a dream about that about a week ago and was wondering if I had torqued up the bolt that holds it on. I didn't bother checking before filling with oil and putting a new filter on as I was positive I had tightened it up. :roll:
Always pay attention to those dreams.................its your subconcious checking your work, and trying to tell you that you missed something
Re: Fazer Rebuild
Just has the exhaust off and removed the oil cooler take off and I had torqued it up good and proper. Discovered why it was leaking, the rubber O ring had perished. It must have split when I torqued it up. luckily enough I had a spare on the old engine so replaced it with that and put some gasket sealant around it as well as a double measure.
I now have no leaks and everything is good minus the tapping valves/chain. It''s not too bad so I'm not too worried about it and it don't appear to quieten down once heated up, so could be the chain stretched or tensioner has not set the tension properly. I'm hoping the tensioner will auto tension another notch with a few hundred miles. If not then I shall sort that out at another time. Apparently it's quite common with these bikes that the auto tensioner gets stuck in between notches.
All I have to do now is bleed the back brake as that is as spongy as a, well, a sponge. :roll: Then off for an MOT and Tax, redo the changes in the log book (engine number and new colour) and it will be good to go. :D It does feel very strange to ride as I'm so used to the VTR now.
It feels good to have two bikes running so now if I want I can take on some more intensive work with the VTR like removing the frame/swingarm for powdercoating or spraying. And while one is out of action I have another bike to ride.
Re: Fazer Rebuild
your getting there buddy, i was gonna pop over on the bike but its ferkin cold out there :wtf:
have you made a start on your tank yet?
i look forward to seeing the fazer running in the very near future :thumbup:
