You can't really go by that too accurately, as the cam chains will stretch with the more miles covered and how hard a life the engine has had, including being serviced at the correct intervals or not as the case may be.Mick B wrote:Is that from the top of the locknut to the top of the pinned nut. Mine are around 30mm roughly.I may need to have a bash tomorrow.So its best to back them off with the bike running and do you get plenty of warning so you don't go to far fella ?benny hedges wrote:i think you might have overtensioned them bud - back off a turn and try it again until you get it right.
im left with approx 38mm of thread between the top nut and locknut.
But I agree with Benny, it does sound as if your tensioners are a little on the tight side, or one at least is.
Good luck in getting it sorted,
