I will do after the motTravisZack wrote:My friend's track bike is on a daytime MOT, the only thing he's added is a strip of red LED's for a brake light, purely for safety on the road. Might be worth considering so no one runs in to you and you can always disconnect it at the track.
Got RH fairing back from sprayers, middle part nearly done, ready for assembly and fit Saturday
Fitted mixture screws
Coolant change
Clear coated frame (and f**ked it up so start again tomorrow)
Clear coat exhaust headers
Coolant change
Changed all bolts and nuts for titanium ones
Fitted adjustable levers
New grips
6mm spacer at back
New grips
6mm spacer at back
Aha you know what it is black and yellow...black and yellow !!!
Gave it a service and started to fit the belly pay for the mori headers .
I want the pan as high up as it will go to give me as much ground clearance as possible for them right handers
Fitted my speedo pickup. More sanding on the belly pan
satin vht, over the paint, bit of extra protection against stone chipsWicky wrote:Clear coat exhaust headers
Fitted seat pad / belly pan / number plate .
Still wAinting for the tank :-(
Blurry pic as it just started snowing again and I wanted in .
That belly pan looks a fair bit higher Lloyd. Did it go up much? Does look nice in black.
Ground the pins out of the footrests, so I can fit some shiny new ones.
Cut a slot in frozen screw on the chain guard and got that out.
Cut down the rear brake push rod to get the right pedal height - a good day all round with the Dremel
boring oily stuff.. oil, filter,air filter..
i want out on my bike NOW ffs.. bored with this sh1t weather
Had a big sort out in the garage and finally started to build the tuned engine .
Pistons in crank in , gearbox in .
Need to pop into honda to change the seal they gave me as it's not the correct one for the clutch push rod ,
Them Pistons c clips are a right fecker to locate in and thankfully ck helped fitting them ( well he fitted them for me ) .
I hope to finish it for next weekend and order the shims .
And you never know I might have it fitted for the devon run [THUMBS UP SIGN]
Good work Lloydie
Your putting my build to shame......................hang on everyone is
- agentpineapple
you'll be able to investigate the devon shrubbery at greater speed.......
