Project Blue MK2
bigtwinthing
Re: Project Blue MK2
Post by bigtwinthing »
your good at Polishing, not so sure using a hacksaw!!!. Put a nut on, cut the bolt, wind the nut back, file the edge, wind the nut off, Nicely prepped bolt. Easy in, easy out.
StormyRob
Post by StormyRob »
The nuts look a tad better than they do in the photo. That was just a comparison photo showing how much I had to take off. I did it with a dremel :D happy to now be cutting metal for a reason!
how the hell did you get the forks so polished?
StormyRob
Post by StormyRob »
You should get yourself a polishing wheel kit thing...makes polishing a lot easier.
StormyRob
Post by StormyRob »
Today the side casings were finished as well as the cam covers so I stuck them on. Considering replacing the cam covers bolts but they will do for now. New bolts all round for the engine.
Before its picked up on I am aware the timing inspection thing is also black and it is intentional. It's stuck solid and will be replaced at some point but I've too much to get on with
Anyway here it is...
Sent from my E6653 using Tapatalk
StormyRob
Post by StormyRob »
Sometimes it is the little things that be pleasing. I sanded the rotten oil lines and gave them a little paint.
Radiators next.
You're certainly making good headway there Rob, well done mate :thumbup: :clap:
The forks, engine, front wheel, six pots and oil lines look brilliant 8)
Which paint have you used on the oil lines :?:
StormyRob
Post by StormyRob »
sirch345 wrote:You're certainly making good headway there Rob, well done mate :thumbup: :clap:
Thanks Chris.
I could not get all the rust off the lines as they're so badly corroded. So I've used good old hammerite straight to metal/rust. If it doesn't hold up I'll just do it again but I think it should be OK
Thanks Chris.
I had a feeling you mentioned Hammerite somewhere, was that spray on, heat resistant or non heat resistant :?:
StormyRob
Post by StormyRob »
Just spray on hammerite. I'll see how it goes after a few runs but I think it should be OK.
StormyRob
Post by StormyRob »
I do not think I need to say how pleased I am to have this.
proper droolworthy yokes... :n6013r0: :n6013r0: . lucky man..
Shauned71
Post by Shauned71 »
Ohhh I like those *dribble* yokes. Very *dribble* nice!
StormyRob
Post by StormyRob »
One of a kind literally. Can only thank the man that allowed me to have them!
StormyRob
Post by StormyRob »
Finally an engine inside a frame!
Have to say I absolutely love these
Even a wheel.Image
