That Lloydie likes you, too.bigtwinthing wrote:
i like that Lloydie.
Enough touchy-feelie, now, boys.
Plugged in all the way but was tight !!tony.mon wrote:No, they either work or they don't.lloydie wrote:get lean surges now it was fine before I swapped clutch covers !
Could this ignition pick up be bad ?
Unless you haven't plugged it in fully....
loveing the boxCkennedy wrote:Looking very good Al those six spokes do look good
Today saw the first of the mods on the tuono, see the tuono thread for details, but can you spot the mods? Lloyd your not allowed to answer
Sent from my HTC One using Tapatalk
Get these http://www.ebay.co.uk/itm/231146638626agentpineapple wrote:started cleaning the akra headers by hand, then I got bored and ordered some dremel bits that should make the job a lot easier. I also painted an aftermarket undertray black, sorted out my tiny man cave/shed.
boxed up 5 parcels for collection tomorrow....
ordered them tonight, thanks for the heads up lloydie, I've been using various grades of wet n dry, it was taking for ever, and I have a very short attention splloydie wrote:Get these http://www.ebay.co.uk/itm/231146638626agentpineapple wrote:started cleaning the akra headers by hand, then I got bored and ordered some dremel bits that should make the job a lot easier. I also painted an aftermarket undertray black, sorted out my tiny man cave/shed.
http://www.ebay.co.uk/itm/301148099199
Makes light work of it
yep thats a good way, i used some emery strip, about 2ft long, wrapped around twice and did a sort of see-saw action with GT85 on and that worked a treat.lloydie wrote:With the pads hold one around the pipe and rotate it like your twisting the throttle and if you use a little wd40 too it really shines :-) .
This is the easiest way I've found to do headers
Glsr likes it coarse !!!agentpineapple wrote:all these new winking techniques.....
minus the abrasive materials of course, or should that be coarse.....
