Storm has developed a misfire, which 'I think' is the spark plug in the rear pot. Unfortunately i can't get the plug out due to not having a correct spanner, got standard plug spanners/sockets but they won't go all the way down. Anybody got an aftermarket one they can reccomend.
I've got a feeling Halfords do them. Make sure you get the right size. If my memory is correct it's a 14mm spark plug tool you require But don't hold me to it Best take a spare plug with you if you can
Thanks for that, think you're right that it's 14mm, I have 2 already but they won't go all the way down to the plug, the walls are too thick. Good idea I'll buy plugs tomorrow & take them with me.
Phaeton wrote:Thanks for that, think you're right that it's 14mm, I have 2 already but they won't go all the way down to the plug, the walls are too thick. Good idea I'll buy plugs tomorrow & take them with me.
Alan..
I had the same problem with the front plug, my standard plug sockets wouldn't fit. I still haven't found a socket that will
