How to install a fork brace.
zakisbak
Re: How to install a fork brace.
Post by zakisbak »
Is there a brace inside the mudguard?
There usually is.
zakisbak wrote: Sat Oct 09, 2021 12:04 am Is there a brace inside the mudguard?
There usually is.
No there is no brace on the stock front end.
zakisbak
Post by zakisbak »
Fair enough.
Had my 4th ride today;due to a bit of a flat spot/hunting around 3/4K revs,riding a bit hard,braking a bit hard.
Front end feels ok,but will look into a brace.
Jamoi wrote:I'll be putting my front end back on (with brace) in the next couple of months, I'll also be following your guide Hawk Image
I know it doesn't help if you need pics sooner, but I can take photos as I go?
Well it has only taken me 10 years to take the photos, but I'm a man of my word, so here we go...
The only tips I would add:
Give your stantions a good clean and polish before moving the fork legs through their stroke.
Loosen the fork brace central bolts, so the middle part is loose, tighten the outer clamps on to the fork legs, then tighten up the central brace bolts last. Before finally checking the free up/down fork stroke. This allows the brace to find its own natural width before tightening up the central bolts.
In my case, my axle didn't insert easily, so I loosened the clamp pinch bolts enough to move the fork leg about a fag paper, until my axle could be inserted easily.
*Updated images to show the brace fitted the correct way round - I wanted to try it the other way, but in the interest of not misleading forum members, the pics are now correct*
ItsaKeeper
Post by ItsaKeeper »
Great photos Jamie
I bookmarked this page as I bought a coerce fork brace last year on impulse but never got round to fitting it :roll:
Jamie, in my OCD head, you have fitted the brace in the wrong way round. The Coerce lettering should be at the back!
AMCQ46 wrote:Jamie, in my OCD head, you have fitted the brace in the wrong way round. The Coerce lettering should be at the back!
I used to have it the other way round, I just thought I'd try it this way round ImageImage
**I'll flip it around and update the pics above**
Any reason you can think of, that I can't have it with "Coerce" at the front?
