So, quick question -given all fluids now changed, I am going to take everyone's advice and will be changing reg/rec before the season starts proper.
I found this one on line - from 2019 on BMW S1000 RR - should I go for it do you think and will it fit relatively easily - and is the Mosfet one that has been mentioned? The adverts says 2019-ON BMW S1000 RR Regulator/ Rectifier - 12318523367
Code on it is FH027AB
And above that is the number 94676-1801
Hopefully the fitting is do-able by someone with limited spannering skills?!
Any advice much appreciated, as the horror stories of not doing this mod are freaking me out!
![Image](https://i.postimg.cc/hzK9kvZy/s-l1600.jpg)
