Not today but earlier in the week.
Got the Firestorm mot'd Wednesday gone, all good, passed :thumbup:
Well done Chris, another year sorted
Duffy1964 wrote: Sat Sep 24, 2022 9:15 pm Well done Chris, another year sorted Image
Cheers Duffy :thumbup:
Fettled Hamburg as promised.
Clean,Lube & adjust chain.
Check oil level.
Check tyre pressures.
Swapped the tank over.
Fitted a Baglux cover.
Fitted an LED headlight.
Re: what have you done to one of your "bikes" today
Started stripping Claggy down, Just taking all the fluids out to start with.
Oil & coolent.
All the hydraulics, brakes & clutch.
Took the callipers off as well.
Covered it up as it's staying out side from now on.
Spanners, plus gas & hammers at the ready for tomorow... :lol: :lol:
Franks taking orders if you need any bits...
Nothing actually fitted lately, but I've just bought a pair of R and G clutch and alternator covers for the 2 oh no for £75 delivered. Perfect condition with the correct fitting bolts, less than half price.
I have a couple of carbon bits to fit, and for the first time ever, a helicoil insert as I managed to strip an m6 fairing bolt thread in the frame.
Never needed a helicoil before, let's see what all the fuss is about...
swore at the elephant that fitted the front sprocket on the Pegaso. i wanted to go up a tooth on the front to ease cruising speeds on it, after much use of very long bars and curse words. iv left the standard gearing on :sad2 :sad2
fabiostar wrote: Thu Oct 06, 2022 7:26 pm swore at the elephant that fitted the front sprocket on the Pegaso. i wanted to go up a tooth on the front to ease cruising speeds on it, after much use of very long bars and curse words. iv left the standard gearing on :sad2 :sad2
These long bars of which you speak; Wetherspoons?
Take it to a tyre fitters- their impact guns shift anything.
tony.mon wrote: Fri Oct 07, 2022 9:39 am
actually good thinking :thumbup: :thumbup:
today my nice heated grips arrived so they got fitted.R&G jobbies for £34 do the very job.
Got another good ride-out in today before the weather changes 8) 8)
Smugly rode about on peggy to try the heated grips :clap: :clap: well toasty i have to say :thumbup:
I had never used heated grips until I tried them on the Multistrada, got to say I’m a fan of them now
Duffy1964 wrote: Sat Oct 08, 2022 5:14 pm I had never used heated grips until I tried them on the Multistrada, got to say I’m a fan of them now Image
bloody great things for old hands :clap:
masterdave
Post by masterdave »
Took out the long stack and fitted a short to make two shorts, removed the screw that somewhere in its life caused one of its previous owners to cut the corner off the air box lid (not sure why as with a decent screwdriver it came out fairly easily), checked the air filter, and got a shock spacer coming from a friend to speed up the lazy handling! Still getting used to having the replacement tyres on it, especially the 190 60 at the rear. Happy with the handing with the new fork oil and a tad extra preload. Shock spacer should finish it off.
see if this link works
