Exhaust Mods Finished
RobVTwin
Post by RobVTwin »
Simple mod (apart from some welding), stunning result!
mik_str
Re: Exhaust Mods Finished
Post by mik_str »
Looks great; better than low and high-mount IMO. Nice job!
Looking good, well done.
8) :clap: Good looking work,
JazzmasterJ
Post by JazzmasterJ »
Very nice - love the upswept look
TheBozBoz
Post by TheBozBoz »
Looks awesome! Just a simple cut, bend, reweld with a bit of replacement tube???
Sent from my G3311 using Tapatalk
RobVTwin
Post by RobVTwin »
Really simple.
(1) I made a single cut through approx 60% of the link pipes as shown below. I drilled small holes at the ends of the cuts to prevent the cuts from cracking more.
(2) Made up exhaust hangers to suit where I wanted the cans to be.
(3) Ease the exhaust cans up to the new hangers allowing the link pipes to deflect into position and bolt up.
(4) Weld up. My guy cut slithers of stainless steel tube to suit the gap which was 8 to 10mm in my case reducing to zero. Stainless steel welded into position and job done.
Here's the finished job. Can't really be seen as the welding is generally on the underside of the pipes which are partly hidden by the footpegs.
so much nicer looking sitting like that :thumbup:
TheBozBoz
Post by TheBozBoz »
Bugger I've just realised if I attempt it my givi top box bracket will be in the way of the pipes!
MK_WF
Post by MK_WF »
Good idea and result, but for my taste the welding could be prettier.
Stainless is so thankful for good preparation and proper rod/needle/lens/gas combinations.
For example this is what I did from a set of stock end cans by cutting them off and weld on a set of formerly high-up sharks.
(And I'm not even a trained welder but just an ambitious amateur)
Bye
Martin
RobVTwin
Post by RobVTwin »
''Good idea and result, but for my taste the welding could be prettier''
Ha Ha, you've seen Honda's efforts on the collectors ;)
MK_WF
Post by MK_WF »
Good point, but I was more referring to my own expectations on welding :-)
BTW: have a look at Suzuki welds and you'll never complain about Honda anymore. Especially aluminum on locations you don't see is horrible there.
Generally all OEM's focus on quick fabrication not on aestheticis wherever you don't look. And here MIG done by "trained monkeys" is the weapon of choice which usually can't compete to TIG done by skilled staff.
In your case a bit of grinding / polishing could have served as a camouflage, but that door is still open...
Bye
Martin
RobVTwin
Post by RobVTwin »
MK_WF wrote: Thu Jan 07, 2021 5:11 pm In your case a bit of grinding / polishing could have served as a camouflage, but that door is still open...
I could do some grinding and polishing in the future.
DJWALKER
Post by DJWALKER »
Old thread i know but have to say that looks brilliant 👏 although the weight saving is a bonus with after market but that looks spot on pal.
Torque
Post by Torque »
That's the sort of angle I'd like on mine - looking good. The VRM on my VTR is very close to yours Y4** RRV - I had to double take! :lol:
