OK, all you. Storm troopers.
Here are the directions to the new bunkhouse, for those that have been to the previous bunkhouse it's almost the same roads.
As you enter Rhayader on the A470 turn onto the B4518 sign posted for St Harmon, continue along this road for 1.5 miles until you come to a telephone mast on your right hand side, when the mast is directly on your right, turn right onto a single track road, this is the the road to the bunkhouse, just continue straight along this road for 0.7 miles, the bunkhouse entrance will be on your left.
The address and post code is :-
Beili Neuadd
Rhayader
Powys
LD6 5NS
It's probably best to use the Sat Nav as a guide only, I believe it will take you to a farm further down the road, so best to use the directions I've given.
I will be putting some signs up with a green arrow indicating the direction to follow, these will match the latter part of the journey described above from the Telephone mast.
These signs will be about 14" square with a green arrow on a white background, placed about 2ft high off the ground on the left hand side of the road, this is mainly for Tony, to save him riding around Wales for half the night
To familiarise yourself with the signs, I will post a picture of one of them on the WhatSapp group message
