Cooling System - Vacume in system?
Bink
Post by Bink »
I might be describing the fault and the cause here but I am hoping some one can explain to me what is happening.
During the weekend cleaning of teh bike I noticed that my lower radiator joint hose had taken an oval shape (starting at the bottom of the right hand radiator). Which I thought could possibly indicate that there is a vacuum in the cooling system.
On the fault finding mission which followed I noticed that the pipe returns back to it's round shape once the radiator cap has been taken off. (coolant was slightly low so I topped it up)
I also found that the Siphon tube to the Reserve tank seems blocked.
I am not sure if this is part of the cooling system loop and therefore not sure if this explains the vacuum?
Could anyone explain/confirm what the problem is or might be?
Would anybody know how to remedy a hose pipe blockage?
Thx!
yellafella
Post by yellafella »
I'd second that.
Bink
Post by Bink »
Hi Lads,
Excuse my ignorance but could you please explain what a 'stuck thermostat' is?
It is not stuck in the sense that it always reads the same temperature. (i.e. the needles rises steadily when sitting in traffic and then the fan comes on)
Thanks again!
Hi Bink,
I'm I right in thinking you changed your coolant on your Firestorm recently :?:
iggy1966
Post by iggy1966 »
Bink
If the syphon tube back to the resevoir is blocked, that will be your problem, the coolant heats up and passes some of the expansion pressure back to the resevoir, as it cools down and contracts you'll get a negative pressure in the tubes.
"Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."
Bink
Post by Bink »
sirch345 wrote:Hi Bink,
Hé Chris - not recently anymore. But I did change it about 4-5 moths ago.
Anybody any idea how to unblock the siphon? Could it be as simple as pushing a copper wire down the tube?
Cheers so far so the words of advise.
tony.wilde1
Post by tony.wilde1 »
you have indeed got a vacuum in the system,thats what makes the bike DY-SON. :lol:
tony.wilde1 wrote:you have indeed got a vacuum in the system,thats what makes the bike DY-SON. :lol:
:lol: :lol: :lol: Keep taking the tablets Tony :!: :lol: :lol: :lol:
