Keihin
Beef
Keihin
Post by Beef »
Fitting the fekkin spring back in the carbs :evil: :lol: :lol: :lol: :lol:
Re: Keihin
Once you get the trick down its not all that difficult.... :D
Re: Keihin
No....
Until you're trying to show someone how easy it is, then it's a nightmare on a groundhog day repeat cycle.
Varastorm
Re: Keihin
Post by Varastorm »
My method is to put pencil into the carb top tube & compress the spring over/down it into the top. Remove the pencil & hold the spring there with your finger.
Then with my 2 two tie wrap tool loop that fits over the top of the carb top & spring hole to hold the spring in the carb top.
Then place the carb top over the carb slide & when the spring is directly over the slide move the tie wrap. The spring will fire into the slide. Job done :thumbup:
Btw, it's a lot easier doing it than typing it :lol: :thumbup:
