Been reading many many forum-topics about the dreaded CCT failures.
While riding at about 40Km/h my bike suddenly, out of the blue (worked like a charm before) started to puff-tick-clankish-sound from the bottom front (hard to say exactly while on the bike, being a bit startled by the phenomenon)...
Soooo... beforehand read a lot already about CCT's, but never got around to changing the original Honda ones. After hearing the sound, I immeditately pulled the clutch, stopped the bike and put it off. Never starting it afterwards...
Last week I began the journey of taking the bike apart for the first time. I actually enjoyed that
viewtopic.php?t=28583 --> Thank you so much!!
Now, the rear cilinder cams look fine, but the fronts... ouch... They're out of sync even without having measured them precisely.
![Image](https://www.racing-statistics.com/images/tmp/IMG_0110.jpg)
My question is this:
I will need to realign these cams first. I am not going to crank my engine while they're this out of whack, because then I'll just be kissing piston with valves (more than they might have already).
So... can I just remove the cams and align them the right way? I mean, when the cams are removed, all the valves are UP right?!
I can then crank the engine over (by rear-wheel, because the damn alternator nut won't ever come off!).
My idea;
Mind you, all necessary or blocking parts are off already. All fluids are even drained ;).
1. remove CCT
2. remove upper chain guide
3. with the loose chain, remove the cams (along with the attached sprockets). Hold the chain, don't drop it.
4. crank the engine to the FT mark. Check if the OTHER (rear) cilinder has its cams facing downward, so on the oposite stroke from the front (if that makes sense).
5. place the cams back, aligning them properly (upward, outward, aligned). Bolt them down up to spec.
6. place the chain guide and the CCT back (manuals this time), tension the CCT.
7. See what valve-clearances I have and do a compression check
Hope the above makes any sense.
I realise that my valves are probably bent, but I'm not asuming anything. I wish to measure these (the clearance) once the timing is in order. Probably do a compression test too.
Thanks for the advice everyone
