Yes mate. Front definitely. Will check rear tomorrow just to confirm matefreeridenick wrote: ↑Thu Oct 05, 2017 10:17 pm Do you need a piston? I've got at least one you can have.
Front and rear pistons?
- StormyRob
Re: Front and rear pistons?
As the others have said, many thanks for taking the time to do that and for supplying the photo's
Good question Rob, I wouldn't had thought there was a difference. I wonder if the JE high compression pistons are off-set the same
I Think so.
Consider that now, on modern engines (as for car as for motorcycle) manufacturers have two ways to reduce vibrations and friction: piston's pin offset or crankshaft offset (vs cylinder's axle).
Most used is pin's offset.
Thanks for that information
- freeridenick
I've just had it confirmed that the JE pistons I'm going to fit can be used in either cylinder. That's direct from JE.sirch345 wrote: ↑Wed Oct 11, 2017 12:01 pmThanks for that information
Thanks for that informationfreeridenick wrote: ↑Tue Dec 12, 2017 6:58 pmI've just had it confirmed that the JE pistons I'm going to fit can be used in either cylinder. That's direct from JE.
That must mean the JE pistons are not off-set like the original ones are,
The Mori pistons are the same and also can be run in either cylinderfreeridenick wrote: ↑Tue Dec 12, 2017 6:58 pm I've just had it confirmed that the JE pistons I'm going to fit can be used in either cylinder. That's direct from JE.
Though that doesn't mean they are not offset.
