fireblade yoke with Aluminium stem pressed out to be used for the conversion
![Image](http://uploads.tapatalk-cdn.com/20171208/3acabe3fa0201390f54c8e9ab76b35cb.jpg)
top is the fire blade yoke where the donor stem was removed from
the black stem is from the Aprillia
![Image](http://uploads.tapatalk-cdn.com/20171208/ce968e82d476e505ec83dfb7074e6653.jpg)
the Fireblade stem now fitted to the Aprillia yokes
![Image](http://uploads.tapatalk-cdn.com/20171208/411633857b0dd216a08e429e043f8668.jpg)
The workshop had to make a spacer that was a press fit on the Blade stem, then turn it down till it was the same diameter as the Aprillia stem, then they press fitted and glued that into the Aprillia yoke
![Image](http://uploads.tapatalk-cdn.com/20171208/7e00b2d600d20a266a1a7a1bd4298cf1.jpg)
![Image](http://uploads.tapatalk-cdn.com/20171208/947bbdbca24dea7f4e241002c0027005.jpg)
