Yesterday I took the part-worn but still good Racetec's off the Sp2, as I can't get enough heat into them on the roads to get the benefit.
I've stuck a pair of Sportsmart 2's on, and new pads all round.
Vesrah, not as good as the Bendix pads I had on there before, but they're not bedded in yet, so I'll give them a chance.
I have a set of part-used Brembo pads to go on as well, to give them a try.
And on the little 600 commuter I finally gave in and fitted a set of sprockets and a chain.
I had my money's worth out of the old ones, though:
This set should see the bike out, as it has a scotoiler fitted. The front sprocket lasted well enough- it's a standard Honda one with the sound deadener rubbers. They didn't deaden the sound of the chain jumping over the stubs of the teeth when pulling away all last week, though!.
