SP brake disc
Moderator: VTRDark
SP brake disc
Bit of a long shot but anyone got a straight right hand side disc?
Re: SP brake disc
ffs is yours warped then mate?
i'll ask around but as you say, it's a long shot....
speak to kevl
speak to kevl
Re: SP brake disc
It is unfortunately I was hoping to find one relatively close so I could just go pick it up, i've posted on the local bike group on facebook as well but can see me having to buy a new pair before Spain
Re: SP brake disc
balls, not sure if matt has my ols pair of 330mm Armstrong wavy discs, i'm sure they'll fit, but give kev a shout, as he had oem sp discs, but changed to pfm discsplayerone wrote:It is unfortunately I was hoping to find one relatively close so I could just go pick it up, i've posted on the local bike group on facebook as well but can see me having to buy a new pair before Spain
- Pete.L
Re: SP brake disc
Don't forget you need the carrier too.
Is it also the same as the fireblade 929 or is it the 954 ?.... or are they both the same?
Re: SP brake disc
929/954 have the same bolt pattern pete, iirc the 929 is 320mm and the 954 is 330mm....Pete.L wrote:Don't forget you need the carrier too.
Re: SP brake disc
I've just bit the bullet and ordered a new set of armstrong disc's, should be here thurs so might get a few miles under my belt before the trip
Re: SP brake disc
are the pads new mate?playerone wrote:I've just bit the bullet and ordered a new set of armstrong disc's, should be here thurs so might get a few miles under my belt before the trip
it won't take long to bed them in over here mate...
Re: SP brake disc
they are
- Pete.L
Re: SP brake disc
Excellent!
Give me a shout when you want to fit them and I'll drag out my trusty torque wrench and special Firestorm plank. It'd be good to get a few miles on the bike before we leave just incase there are any other little gremlins to get sorted.
Re: SP brake disc
sounds like a good offer, or is that Bristol speak, for two men having a shag in the forest....Pete.L wrote:Excellent!
