CCT Failure
Re: CCT Failure
I think you need your bumps felt fella. Given all of the evidence about the stock tensioners and ,hopefully, having been very fortunate when one failed and despite being a member on here since 2013, when every other post is concerned with failed tensioners/ timing issues, to stick another bullet into the revolver and have another go at Russian roulette seems a little daft to me.
Good luck with it though.
Re: CCT Failure
Should be ok just to fit them and do the measurements then remove and do stopper
Re: CCT Failure
Running the engine before doing the Stopper Mod with your brand new standard CCT's fitted would be the best way to go, although you will need to leave the engine until it's cold before carrying out this Modification,Troutman wrote:Ok but do I need to run the engine or is it just a case of fitting them, locking them off, measuring etc and doing the stopper mod?
I want to keep the OEM tensioners rather than converting to manual's or converting them to manuals as I think I like the idea of some dynamic movement going on in there.
Re: CCT Failure
OK I'll rig up a small tank so I don't have to put the tank back on.
- KermitLeFrog
Re: CCT Failure
Another option might be to turn the engine over a few times (30 seconds?) with the starter motor (plugs out). That should get them into the correct position? That way you don't have to re-fit carbs etc...
Re: CCT Failure
I had exactly the same with the red one, before I found this place and read about them, took it to a garage down here and they said "oh it's fine to keep riding it, we need to order the tensioners so bring it back next week"...........I guess I was very lucky as I did keep riding it!!!!!!!Shauned71 wrote:Fingers crossed tightly for you that you get lucky... My cct's started to rattle like hell a month or so after I bought my first storm. I rode around for a few days like it too because I had no idea at the time what the problem was. I got lucky, swapped out for new ccts and off I went.
Re: CCT Failure
You probably would be okay doing it that way.AMCQ46 wrote:Should be ok just to fit them and do the measurements then remove and do stopper
That sounds like a good suggestion, that will save you having to wait for the engine to cool down. Just remember to realign the timing marks before removing the CCT's. Also remember the metal cap on the plunger head needs changing over from the old CCT to the new ones,KermitLeFrog wrote:Another option might be to turn the engine over a few times (30 seconds?) with the starter motor (plugs out). That should get them into the correct position? That way you don't have to re-fit carbs etc...
http://vtr1000.org/phpBB3/viewtopic.php?f=31&t=19416
Re: CCT Failure
Thanks for reminding me about that. I like the idea of using the starter motor rather than carb refit. Just come back to get a camera so things go back together as they should.
I am lucky enough to own a Ducati 1000SS DS as well as the Firestorm, took it out for a blast this morning, fantastic.
Re: CCT Failure
HELP PLEASE..
So the rear timing is fine, I was hoping to not have to remove the entire front end and just turn the engine 415degrees so the front will be set for the new tensioner but do you think it would be best to remove the fairing etc so I can get the front cam cover off and make sure the timing is where it should be.
Bear in mind the engine was still running properly when the tensioner failed, I shut the engine off as it was rattling badly. If the timing chain had jumped then surely it would at best have been missing, popping etc...at worst bent valves and a non runner.
When I turned the engine anti-clockwise to get the RT mark lined up just now it was rattling from the front cylinder as tension came on from the cams.
Re: CCT Failure
If its rattling as bad as you describe (and it usually the front one that goes) then a quick check of the valve clearances will confirm if damage has been done necessiting head work. So grit your teeth and dig in deep to access the front head.
Re: CCT Failure
First of all it's anti-clockwise 450 degrees (one and a quarter turns) not 415 degreesTroutman wrote:HELP PLEASE..
I would remove the front cam cover (as Wicky says) and check that the timing marks all line up correctly seeing as you have had a CCT failure. From what you've been saying you'll probably be okay, but definitely worth checking while you at it,
Re: CCT Failure
I agree best to play on the safe side. The hardest part with the front cylinder is making sure that the cam cover rubber gasket sits correctly when refitting. As for the rest it's not difficult just time consuming if your not used to it.
Re: CCT Failure
OK i'll dig deep and carry on..450degrees of course (360+90) .
Front CCT spring!
https://serving.photos.photobox.com/121 ... 47f236.jpg
https://serving.photos.photobox.com/239 ... f40949.jpg
Can someone make the photos appear?
Front CCT spring!
Re: CCT Failure
It doesn't look like it, the links only take you to PhotoBox, no photo's showing to link up with, just this:-Troutman wrote:
Re: CCT Failure
Would a White rabbit out of hat do insteadCan someone make the photos appear?
