VTR Cafe Fighter Project
Re: VTR Cafe Fighter Project
You're doing a top job mate, well done
These turned up today; bar end indicators.
Gonna route the wires through the switch gear and along with the other wires.
If it's broken; should it move? Yes: Use WD40 No: Use cable ties. Now it's fixed!
Yes it does and those indicators are intresting
Can't wait to see this finished,really liking the finish on frame and swing arm is the bike going to be a keeper or sell on to make way for another project
Your make light work of this [THUMBS UP SIGN].
Keep it up
Keep it up
Cheers Carl, they are really good for an order from China job.
Plan is to keep it for a good while, then maybe trade up to another one.vtwin goody wrote:Can't wait to see this finished,really liking the finish on frame and swing arm is the bike going to be a keeper or sell on to make way for another project
I must admit Ant I've not seen indicators like that before,
Just a little update, been working on the linkages and swing arm. New bearings all round so should feel like new! I've also ordered some tube to build a new sub frame so will update when I get started.
Cheers Chris, thats what I was going for. I'm an industrial designer by trade so it's a case of using what I know. I've also taken a lot of inspiration from the nrw yamahas.
Got the back end mostly assembled today gonna find someone local to powdercoat the spring this week.
Should there be free play in the linkages by the way? Got 3mm od free play left to right......
No you shouldn't have any free play in the linkages. Did you torque them all up 33 lb ft and have you got the little slideout spacer in the bottom of the shock. I have been doing the same today. Got my back end back on the bike.
I want to get some of that truck liner paint now. I really like the look you have achieved there. I also like the way you have continued it on over the chain adjuster end but leaving the inner bits ally. Looks fantastic. Have you not got the rubber that goes over the swingarm on the chain side. It will protect it. And you might want a spring on that shock
