Sorry for always more than my bad English, I wanted to know if the flywheel was changed from 1 to 2 FIREHAWK series of series 2002 are interchangeable, have the same weight?
Thank you
I have been running the bike for over a year now with the 4lb 5.8oz flywheel.
I can happily report that I have experienced no bad issues what so ever. I was a little wary about it exploding at high revs tbh, but I've covered over 5000 miles with it fitted & regularly thrash it to the 9000rpm redline. The acceleration is so impressive, I think it borders on being addictive.
My only issue is that I've got used to it now & would like to go lighter
Varastorm wrote:Update on the Ultra light flywheel (Benny's cut).
you hound lol... try putting a standard one back in. i did and it lasted about 3 days lol
Rolling on that post..
I too have run an ultra light flywheel for well over a year now, almost two..... and the only concern I had was an imbalance causing additional wear on the crank plan bearings.
Post crash in Jan, I split the cases on my spare motor which has 16,000 miles and the motor that was in my crashed bike.
Bearing wear on the 62,000 mile motor was hardly more than the low mile motor and plastigage confirmed the visual inspection.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
I really want mine done but cant afford the cost of paying someone to do it, any chance of having a detailed image of how much needs to come off so i can find a friend with a lathe and try it myself.
of course i can exchange a set of carbs for the work ;) lmao
vtr parts coming out my ears but no light flywheels
