Not all today (the mirror indi's were saturday).
Fitted new mirrors with integrated led indicators. The bases for mounting to the bike were a bit pony but on closer inspection and investigative disassembly
I found that the new mirror stems fitted on to the original honda mounts, happy days
Not everybodys cup of tea but i like them
Today was the coloured led lamps in the dashboard.
I kept to the original colours for the idiot lights i.e green for indicators, red for oil etc and went for red behind the rev counter, speedo and temp guage.
Wow the idiot lights are bright now!!!
Excuse the blurry pic, or not I'm not fussed
And i like the red clocks too
All the led lamps i bought were cheap as chips from china but only came in packs of 10! This means i have spares available if any one wants a couple. (Red, white, green and blue)
Pm if you want any, first come first served as usual
Sounds like thunder, goes like lightning!!
Could you get the pictures any smaller?
I could try mate but i dont think sokev64 wrote:Could you get the pictures any smaller?
I dont know why they come out that small, they never used to
- freeridenick
I was looking at integrated indicators/mirrors to replace knackered mirrors and a cracked indicator mount holes. Read on here that they were pants, but your's look all right.
Where were they from? I've got replacement mirrors but the indicator holes would be easier to just fill and blank off.
I got mine from evil bay.
Mixed reviews on these but for the price they're worth a go.
They also have amber led arrows which flash in the mirror glass when indicators are on. More visible to the rear plus you can see if you've left them flashing!
Like i said though the mounts are a bit rubbish so unbolt the standard ones and put them on these if you get them and they fit much better..
Not sure how to post evilbay links from my mobile but this is the item number for the ones i bought
151308298272
151308298272
Link...mr-jeff wrote:I got mine from evil bay.
151308298272
http://www.ebay.co.uk/itm/151308298272? ... 26_rdc%3D1
Show offMacV2 wrote:Link...mr-jeff wrote:I got mine from evil bay.
151308298272
Reassembled it, scraped some dead flies off the headlight lens, I'll ride it to work tomorrow and see if it breaks down.
If not, off to Wales.
If it does, fix it again and off to Wales....
Good move Tony think of the weight saving !tony.mon wrote:Reassembled it, scraped some dead flies off the headlight lens, I'll ride it to work tomorrow and see if it breaks down.
- Pete.L
What about the oil leak Tony?
What did that turn out to be?
Engine oil changed
Gave it a bit of a clean
Tried adjusting mixture screws but gave up and set them back
to what they were, runs ok
Ready for Wales now
Ready for Wales now
As I suspected, I'd left an o ring off the speedo sensor.Pete.L wrote:What about the oil leak Tony?
I rode it to work today, nice journey in but it went onto front cylinder only about five miles from home, and cut out the second cylinder two hundred yards from home, coasted onto the drive.....result.
A fuse blew powering the fuel pump, they apparently draw more than two amps.
Fixed that, let's see how far I get.....
- bigtwinthing
Pushed it out the garage ready to ride to work, Yahoo, Out tomorrow to dorset too, then Sunday. Fishing. Should be a good weekend. You Guys off to Wales have a good un.
- Pete.L
tony.mon wrote:As I suspected, I'd left an o ring off the speedo sensor.
Cool Have a good trip. Hopefully that's it and you are all set for an successful weekendtony.mon wrote:A fuse blew powering the fuel pump, they apparently draw more than two amps.Fixed that, let's see how far I get.....
