They look like M6.
Also, what's the best way to drain the fuel tank? No mention of it in the Honda manual.
Ta
What size and thread are the chain adjuster bolts?
- freeridenick
Re: What size and thread are the chain adjuster bolts?
Not sure of the top of my head - worth getting a Pro-bolt bolt thread tool >freeridenick wrote:They look like M6.
Ta
Ride about 90 miles and then some more...Also, what's the best way to drain the fuel tank?
When i emptied my tank i just got cheap plastic siphon tube from the auto factors - just compress the concertina bit and hey presto the fuel flows into a can !!!!
Simples
Simples
- freeridenick
OrderedNot sure of the top of my head - worth getting a Pro-bolt bolt thread tool >
If only I didn't need to remove the fuel 'cause it's old and clogged the carbs that would work.Ride about 90 miles and then some more...
- freeridenick
Halfords it is then. Ta.BrianC wrote:When i emptied my tank i just got cheap plastic siphon tube from the auto factors - just compress the concertina bit and hey presto the fuel flows into a can !!!!
Simples
Chain adjuster is 8mm so wouldn't that be an M8 then.
- freeridenick
Just looked at them with a rule and my bad eyesight. Not surprised I'm wrong.cybercarl wrote:Chain adjuster is 8mm so wouldn't that be an M8 then.
i checked earlier and i'm with carl on this...M8.....
