LED running lights - options
- Pem Brooke
Finally fitted an LED I bought on flea bay...think I paid 11 quid for 2 so nothing to lose. Wired it to the sidelight wiring....easy mod and can always take it off if needed.....
Twist it 'til it breaks, then back off half a turn....
Re: LED running lights - options
cannot believe it ,exactly the same as mine and in the same position also.
did wonder if it might disrupt airflow to oil cooler?
I bet you haven't got a TEAL bike though 10Robbo.
Theres A Hare in The Turnips.
youre right I havnt got teal,but ive always known its the best colour
obviously got taste robbo10robbo wrote:youre right I havnt got teal,but ive always known its the best colour
- Furrybiker
Looks very neat and we need all the visibility we can get at warp factor TEAL!!
Furrybiker wrote:Looks very neat and we need all the visibility we can get at warp factor TEAL!!
I think the purpose of the lights is not to be seen. Blind those from seeing it's Teal
You don't mess about Pem. You have only just got the bike here and already your modifying. Looks very effective.
Pem, what and how have you mounted these lights on .
also where did you take the wiring back to??
cheers
cheers
I'm thinking about fitting a pair of these:
http://www.ebay.co.uk/itm/181455298314? ... EBIDX%3AIT
bald_pig wrote:I'm thinking about fitting a pair of these:
they could be a good aid to being seen
just a question of where to stick them ?
With a little work one will fit into the std side light holder.lumpyv wrote:bald_pig wrote:I'm thinking about fitting a pair of these:
I've done one on Nue Red & will be doing the one on Smoking Joe...when I get round to it...
Basically you have to cut the back of the sidelight bulb holder off, make the hole round to fit in the new LED then wire in to the loom.
I didn't want to cut the loom & you have to be able to disconnect it to get the fairing off remember. So I just used some flat spade clips which push into the block on the loom. Not perfect but it works, although I will look at a different way of wiring it up.
Originally I was looking at putting one in each of the air ducts, made some brackets up all ready, never did it as I was loath to drill the holes to fix them in place & the wiring in would have been a bit messy...
thank you mac . I bought a couple of the strip type sets about 2 years ago for something like £3 ?? and have never got round to fitting them some where ( like my grab rail and braided rear brake line )
I was planning on fitting it in the vent hole thingies on the front
