why jamoi whats the problem forks to far through the yokeI have a Deuville top yoke you can have
But it doesn't fit!!![]()
![Question :?:](./images/smilies/icon_question.gif)
Moderator: VTRDark
The stem hole is 10mm to far forwards...macdee wrote:why jamoi whats the problem forks to far through the yoke
Could you fit the lower yoke too ?Jamoi wrote:The stem hole is 10mm to far forwards...macdee wrote:why jamoi whats the problem forks to far through the yoke
It would be possible to modify the hole but, to be honest I couldn't justify all the work as the ignition barrel etc would need playing with too.
It could be used as a lower yoke reinforcement mod though
YepJamoi wrote:Not sure I follow Lloydie? The lower yoke from a deuville?
