Well this is where I think half the problem is as Lee has nothing to get the fuel in accept gravity.If this is the case have you used the full 19 Liter setup ie the external petcock arrangement that sits behind the tank??
Now, excuse my ignorance, but why would that be an issue? Really?!cybercarl wrote:Well this is where I think half the problem is as Lee has nothing to get the fuel in accept gravity.If this is the case have you used the full 19 Liter setup ie the external petcock arrangement that sits behind the tank??
+1...As I understand it, all the vacuum hose does is open/close the petcock, bugger all else. Gravity does the rest...Tweety wrote:Now, excuse my ignorance, but why would that be an issue? Really?!cybercarl wrote:Well this is where I think half the problem is as Lee has nothing to get the fuel in accept gravity.If this is the case have you used the full 19 Liter setup ie the external petcock arrangement that sits behind the tank??
The guys having a 19L tank on their bike to start with, haven't got anything else helping them, AFAIK... And, neither have you... So why?
The petcock is opened by vacuum, not helping the fuel flow in any way by use of vacuum... All post 2001 VTR's in the whole of Europe get's by on gravity alone...
I personally believe that unless it's now solved by unblocking the overflow, any residual issues can perhaps be traced to his earlier kinks and bends in the pipe, from having what was believed to be the wrong version Varadero tap, and perhaps the wrong angle/length/width pipe at some point...
Mines running fine now, no vacuum required with the vara tap. The original vac hose is bunged with a bolt, ready for carb balancing.ant76p wrote:i had the same problem when i had one fitted to mine .then i finally found the problem!.
it ran fine when raised the rear of the tank up but as i lowered the tank down i noticed the fuel hose which fed the rear carb ( if sat on the bike it was the hose that goes to the right of the bike) was kincking and trapping off the flow.
i never blanked off any breathers.
i bought the tank off benny hedges and had it running on a t piece(splitter) and then machined a adapter to fit to petcock .so it would help pump it via the vacuum.
No fuel pump on these. They work of the Vacuum. Gravity should work OK as long as there are no kinks or strange roller coaster type routing for the fuel lines. A fuel pump or vacuum is just a helping hand added to it. IIRC I think it also serves as a safety measure to stop the cylinders flooding with fuel if the float valve/s fail in the carbs.it is sucked out of the tank by the fuel pump
I spoke to a guy who's owned Storms and teaches motorcycle mechanics about this, and the vacuum hose merely opens the diaphram in the petcock, gravity does the rest.cybercarl wrote:No fuel pump on these. They work of the Vacuum. Gravity should work OK as long as there are no kinks or strange roller coaster type routing for the fuel lines. A fuel pump or vacuum is just a helping hand added to it. IIRC I think it also serves as a safety measure to stop the cylinders flooding with fuel if the float valve/s fail in the carbs.it is sucked out of the tank by the fuel pump
Is it because the lowest capacity of the Vardero tank is below the height of fuel entering the carb/FI so it needs to be pumped uphill to overcome gravityStill does'nt explain why a Varadero has a fuel pump , ..at the front of the engine by the oil filter..?? WHY? lol
http://users.bart.nl/~stikfort/new_inte ... ypass.htmlBypassing the pump allows gravity feed and it will work if the fuel level in the tank is not below the carbs.
