fireblade brace
vtrnewboy
fireblade brace
Post by vtrnewboy »
I have got a swing arm brace from a fireblade to fit to the vtr swing arm but the rear caliper hits it do you have to fit the blade caliper bracket or is their another mod to get it to fit , cheers in advance
Re: fireblade brace
Hi there, yes you will need the blade bracket, also you'll need the 'female' bracket locator from the blade swingarm (the bit on the inside right of blade swinger).
Here's a good thread which should outline everything required :thumbup:
http://www.vtr1000.org/phpBB3/viewtopic.php?t=18972
vtrnewboy
Re: fireblade brace
Post by vtrnewboy »
thanks for that noticed the thread after I add posted this :roll: I have a blade swing arm that I cut the bracket off just need a caliper bracket then :)
Re: fireblade brace
Remember you need the bracket that's on the blade arm to fit the caliper bracket on the storms arm .
Re: fireblade brace
and make sure you fit the female bracket in the correct place.... :roll:
Re: fireblade brace
Yep you don't want it on the wrong Side :lol:
