Front forks repaint
- TAFFTHEMAGICDRAGON
Front forks repaint
Has anybody sprayed or painted the fork bottoms as mine look shitty and don't do the bike justice as the rest of the beast is in excellent nick Any ideas?
- yellafella
Did a link not long ago on this very subject ! Will report back when i find it ! Wont be long !
Got it :
http://www.abercon.co.uk/vtr1000/phpBB2 ... ork+lowers
Got it :
![Image](http://i7.photobucket.com/albums/y290/kwakakid355/cooltext12229582.jpg)
I rubbed my forks down when I had the front wheel out for a new tyre, already had the mudguard off so all I did then was remove the brake calipiers, tie them up out of the way, mask off the fork leg protector's then start work. I painted them with brush on Japlac silver paint, which leave's very few brush mark's. I did'nt use paint stripper because once you're down to bare metal seeing as its aluminium you really need to use an acid etched primer!
I've gone the painted route and it looked crap after a while, so now all rubbed down with wire wool, real quick then a couple of nights with the solvol finger then varnish, laquer..........did'nt think I could spell laquer.
now looks good.
Ps paint stripper melts plastic
now looks good.
it may be clever, but its not big.
What type or manufacturer of lacquer did you useRAINMAKER wrote:I've gone the painted route and it looked crap after a while, so now all rubbed down with wire wool, real quick then a couple of nights with the solvol finger then varnish, laquer..........did'nt think I could spell laquer.
now looks good.
![Question :?:](./images/smilies/icon_question.gif)
I remember doing the same thing on all the side caseings on a previous bike. Got the right lacquer from a motor parts supplier, heat resistant and all that, looked good, until one day, I removed the fuel tank and happened to spill a drop of fuel on the one of the caseing and hey presto it melted the lacquer!
You could say I was not amused
Having just washed my bike recently, remembering this thread, I thought I'd give the Japlac painted forks a closer inspection. On inspection I found the finish has started to go off, so I tried to polish them up a bit, but found that the paint started to come off on the polishing rag, I'm not very impressed! Perhaps using a car engine lacquer might be a better option if you don't want to spray them!
I've used Hammerite silver with some success. Rub down with wire wool first to remove loose flakes and provide a key for the paint. Mix the Hammerite with thinners, 1 part thinners to 4 parts paint, and apply a thin coat. Allow to dry, apply further coat.
Key points are to thin the paint, and only apply a thin coat. Think thin![Smile :)](./images/smilies/icon_smile.gif)
“I don’t want to live in a society where some do gooder thinks my safety is more important than my freedom” – Richard Rutan
