2001 Firestorm
- bigtwinthing
2001 Firestorm
hi I have just purchased my first ever "Honda" after 39 yamaha,s. Various types etc but i am loving the Firestorm. I have picked up a 2001 5770 mile bike in great condition with full service history, totally original. What do i need to check on to start?. I have been told about the cam chain tensioners and water pump issues but thats about it. Any feed back ois more than welcome thanks.
Re: 2001 Firestorm
Greetings and a great choice of bike.
Check out the workshop knowledgebase subsection of the forums on how to fix the CCTs, while you're there check to see if the R/R is an early unfinned one, if so replace with a later more efficient finned version (some early storms weren't registered till 2001 when Honda introduced the later revamped model) . Not heard that the water pump has any problems but for such a low milage one that's been sitting most of its life you might want to replace all the fluids and give it a good service. Use the downloadable Honda Service Manual PDF to see what needs doing.
Whereabouts you based? and post some pics of your new Stormbeasty.
Re: 2001 Firestorm
welcome to the Forum, sounds like a nice low milage bike you found.
there are only 2 real reliability issues
1) the Cam Chain Tensioners [CCT] and these can be maid failsafe by fitting a cut to length spacer inside the CCT body, the instructions are in the workshop knowledge base, and people on here are available to talk you through it is you are concerned.
2) the Regulator / Rectifier on early bikes didnt have any heat sink fins so would get hot and fail......this then kills the battery. Fit one from a later model [your might be OK, but I cant remember when the changed, but you can feel if it has fins by lifting the seat off and finding teh R/R bolted to the side of the subframe near the back of the seat.
dont know of any water pump issues
oh and put your location in the user info profile and we can then be able to get local help or ride outs sorted
looks like Wicky got there first with all the same answers
- bigtwinthing
Re: 2001 Firestorm
Many thanks guys. I have got the "finned" regulator and the motor is sweet with only 5775 miles on but i will keep listeneing for a Cam chain rattle.
I have changed the oil.brake fluid and coolant already so it really is ready to have a blast on. handling seems fine at the moment but its a tad wet here (new forest) to give it some serious leans at the moment but it does seem to turn in fine. It has Dunlop Sprotmax qual tyres on but i normally have Pirelli corsa,s but i will give them a try. I have a Givi Box and Givi Arms to sell but not sure how i post this at the moment.
I am not really worried about the fuel consumption as i only use it for fun(quite lucky) i do want to change the cans to extract some better noise as v twins do sound good.
I have had a BT1100 and an MT01 and they sounded awsome on better cans. I had Danmoto cans on my Fazer 1000 (had 3 of these) and they were fantastic.
Many thanks and looking forward to some dryer weather.
Re: 2001 Firestorm
Best take preventative action by fitting manual CCTs ( http://www.vtr1000.org/phpBB3/viewtopic ... 16&t=22720 ) or fixing with the stopper mod, as when the CCT fails it goes suddenly and without warning - and has happened on bikes with milage as low as 7000 miles.the motor is sweet with only 5775 miles on but i will keep listeneing for a Cam chain rattle.
Re: 2001 Firestorm
dont be kidded that you will be able to catch the CCT problem by listening for failure. on this bike [as with any single cylinder or V2 engine] if / when the CCT fails you will get no warning and the force of the valve springs on the Cams is enough to make it jump a few teeth on the sprocket on a loose chain , and the 2 or 3 teeth movement in timing is enough to let the valves hit the piston.
it is best advise to do the stopper mod now and then if there is a failure the chain wont get slack enough to jump a tooth, but you will get a rattle to tell you that you need to get a new CCT
Re: 2001 Firestorm
welcome to the forum buddy, sort out the cct's asap, then you'll having nothing to worry about, what year and colour is your bike???
- bigtwinthing
Re: 2001 Firestorm
hi Bike is a 2001 with the bigger tank and dash etc and is bright red. very happy with it so far, but havent had enough good dry weather to go out and check the handling.I have just changed froma Yam Fazer 1000 and i like the fact that is so different.
Re: 2001 Firestorm
Sounds like you have a very nice bike there and extremely low mileage. To post pics you will need to use an online image host like photobucet or equivalent. Ipload you pics there, then copy and paste the supplied code into your posts.
Welcome to the forum
![beer :beer:](./images/smilies/beer.gif)
Re: 2001 Firestorm
Welcome aboard, I have a 2000 mile one from 1998, not many of us with sub 10,000 mile bikes I don't think ![Smile :)](./images/smilies/icon_smile.gif)
I had a lot of straight fours and single cylinder supermotos and love the V-twin![Smile :)](./images/smilies/icon_smile.gif)
KTM Duke 690ABS in White
Re: 2001 Firestorm
![Image](http://www.lupinblu.co.uk/wp-content/uploads/2012/10/Untitled-1.jpg)
My god where have you guy's found these bikes that that previously been owned by a hermit
Enjoy the bike mate
Re: 2001 Firestorm
Mine been stood for 10 years when I bought it as the owner worked abroad
I had been looking on and off for nearly a year for a really really nice one before I found mine in the summer.
Re: 2001 Firestorm
Welcome aboard bigtwinthing
As already mentioned CCT's (which you already know about) and the rectifier are the two main things that can go wrong, the rest of the bike generally speaking is pretty good if looked after.
Re: 2001 Firestorm
Welcome to the club bigtwinthing. Enjoy the bike and the forum.
- denisblackvtr
