nearly finished. a quick update....
playerone
Re: nearly finished. a quick update....
Post by playerone »
Congratulations, it's a stunning bike and you should rightly be proud :thumbup: now go wind up our American brethren with your latest sucess :lol: :lol: :lol:
rob...
Post by rob... »
another 'best engineering' at the prestigious 'Cheddar Show' a little while ago.
When subjected to an electrical voltage of at least 50 volts, a cat's tail always points toward the north.
scott02464
Post by scott02464 »
Is that you in the pic Rob?
seb421
Post by seb421 »
scott02464 wrote:Is that you in the pic Rob?
he looks like he eats Manchester bike thieves as an appetizer :wink: :wink:
scott02464
And then grinds their bones down to make his bread ;-)
rob...
Post by rob... »
what are you saying? lol.
scott02464
rob... wrote:what are you saying? lol.
That you look like you eat thieving wombles from Manchester then grind their bones up to make bread lol :lol:
That you look like a bit of a, er, Street Fighter!!! :wink:
But in the last pic it looks like rob is holding a tea cake :lol:
Your all heart you lot. :lol:
Your need to do something about the tail storage.
rob...
Post by rob... »
cybercarl wrote:Your all heart you lot. :lol:
as it happens, it has something exactly like that under the headlight now.
thats me waterproofs in a placcy bag on the back.... :D
Xenocide
Post by Xenocide »
They're waterproof... why do they need to be in a plastic waterproof bag? :p
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Trowbridge & Surrounding Areas Lawn Mower Servicing & Repairs
To keep his waterproofs dry. :lol:
rob...
Post by rob... »
5 months of use, lots of miles and it's a bit grubby now.... :lol: :lol: a few changes being done, i've bought a triumph sprint rs to hack about a bit (not streetfighter!!! :lol: :lol: :lol: ) i've put the chops front end into the triumph, and the stubby race can.
bought a king sportster tank, doing some changes to the inlet manifold, (when it 'coughs', like storms do, it sometimes pops the inlet manifold out), so i'm adding a pair of blow-off valves and bolting the manifold to the heads instead of it just being pushed into the inlet stubs.
put the triumph sprint front end and rear wheel into the chop, changing to a different exhaust....
front end dropped straight in, literally, not even a bearing swap! 8)
rear wheel dropped straight in too, same sprocket offset, chain lined up true, same number of teeth on the sprocket....
fireblade 220mm disc fitted straight onto the triumph wheel, replacing the 255mm triumph one. gixxer 1100 slabby caliper hanger fitted straight on, and sat the bandit 1200 caliper in exactly the right place, no extra spacers needed. 8)
rob...
Post by rob... »
once i've got it all up and sorted again, i'll pull it down for a respray and tidy up, still satin black with the silver wheels, and a fancy paint job on the tank...
pipes kinda like this...
