VTR Battery
VTR Battery
Hiya,
Well my battery has given up the ghost and I need a replacement. To be honest I don't think it's ever been 100% as the bike always took some starting, even when the weather was good (it's a pig when cold).
So the question is, do I replace it with exactly the same battery or should a go for something a little more power to aid start up. Are the gel batteries any better? Can I fit something more powerful anyway or will it damage the bike? Last but not least, where is a good place to buy one from?
You comments would be greatly appreciated.
VC
VC
Re: VTR Battery
check out busters, they were selling motobatt gel batteries for £45, the big powerful jobbies with 2 extra terminals, i bought one last year, they are very good, now my bike wants to start,even in cold weather ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
Re: VTR Battery
mine starts fine any weather after a new standard battery ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
http://lincsrideouts.co.uk
![Image](http://i273.photobucket.com/albums/jj222/diabolus10/php4i2ETAAM_zps8ff99f43.jpg)
Re: VTR Battery
Busters have Motobatt battery's on offer for £36. That's for the 9 bsx ,if you get the 12, the battery compartment lid won't close. The 9 throw's mine over fast enough.
Theres A Hare in The Turnips.
- Homers_dad
Re: VTR Battery
Just fitted a Motobat to mine and it's a significant improvememt on a standard battery.
I use mine all year round and when it was cold it was touch and go starting, not any more!
Dance like no ones watching, and live each day as if it's your last.
'cause one day you'll be right!
Re: VTR Battery
i put a 12 on mine, you just leave the lid off, busters are selling them for £45 delivered
Re: VTR Battery
Hi Marty, Something I've been meaning to check myself, I'm I right in thinking the only way to remove the battery box lid is to cut it offbigspanishmarty wrote:i put a 12 on mine, you just leave the lid off, busters are selling them for £45 delivered
![Question :?:](./images/smilies/icon_question.gif)
Re: VTR Battery
Yes, just cut it off.
You could re-attach it higher up if you made hinges out of a spare bit of packing, but it's not needed; you won't miss it.
Re: VTR Battery
Cheers Tony for the info and suggestiontony.mon wrote:Yes, just cut it off.
Re: VTR Battery
That's not too much of a problem, Chris.
The battery compartment lid has three functions, to stop the battery jumping upwards if you hit a bump, to protect and cover the terminals, and to give a locating position for a u lock if you put one under the seat.
Unless you use a u lock, forget that one.
As to the battery jumping up, the relocated lid will still do this, as it can't hinge up much before the front edge hits the underside of the seat.
Lastly, the cover will still protect the terminals.
Your only problem is that in order to remove the battery if a larger one is fitted you have to unclip the fuse box first.
I find, though, that the larger battery fits fairly neatly into the box, and it's own weight coupled with the snug fit keeps it in place.
You could make it even more snug (snugger?) by leaving a couple of lengths of that sharp pallet strapping round and under the battery; it helps when you want to lift it out again.
You could always use a block of expanded polystyrene under the seat instead, but mine has no cover and it's never caused me any problems.
Re: VTR Battery
you can make it easier to take out by putting a strap around the middle(mac put me onto this idea)
you could also put a couple od cable ties around it, would do the same job....![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
Re: VTR Battery
Thanks Tony for your enthusiastic reply, nice one
Now I have no excuse
Thanks to you also Marty for your suggestion, although I thinks it's what Tony spoke about it's still none-the-less a good one
