Mikstr's VTR
mik_str
Mikstr's VTR
Post by mik_str »
Here you go folks, not much left to do on the old girl now.
Sorry for the quality of the pics but it was the best I could do today...
http://s784.photobucket.com/albums/yy12 ... 140067.jpg
http://s784.photobucket.com/albums/yy12 ... 140073.jpg
http://s784.photobucket.com/albums/yy12 ... 140070.jpg
http://s784.photobucket.com/albums/yy12 ... 140068.jpg
Here is the list of mods:
Engine
- JE 0.5 mm OS pistons (11.5:1) with moly skirt coating and ceramic top coat
- Carillo H-beam forged rods
- DLC coated piston pins
- DLC coated intake valves
- Yoshimura Stg 1 cams
- Ported and decked heads (0.015”)
- Balanced crankshaft
- Lightened and balanced flywheel
- Factory Pro detent arm and shift star
- Ceramic transmission bearings (where possible)
- JDM CNC-machined shift lever, fit with needle bearings
- Samco silicone hoses with heat dispersant coated in-line cooler
- Engine Ice coolant
- DJ kit
- TPS adjusted to 430 ohms
- BMC street air filter
- Flo-Commander
- Manual CCTs
- HPower-replica billet long intake runners
- Akrapovic full race exhaust with Ti cans; ceramic coating
- CBR600RR stick coils
- PAIR system removed
- Modded EX400 oil cooler (twice the area)
- Barnett clutch springs
Suspension
- Braced swingarm (900RR), powdercoated black
- 1997 CBR900RR (45mm) forks (with Gold Valve kit and valving specs from Roger Ditchfield)
- Ohlins fork springs (0.90 kg/mm)
- Ontario Moto Tech triple clamps (all aluminum; 5mm less offset), had them anodized red
- Ohlins two-way adjustable rear shock with hydraulic preload adjustment
- 6 mm shock shim
Chassis and bodywork
- reinforced steering head and braces
- Mototeck undertail
- LED taillight with integrated signals
- Lockhart Phillips front turn signals
- Eastern Beaver headlight relay kit
- Hella 100/55W headlight bulb
- Removed front “air duct” panels, fit screens at front
- Removed radiator screens
- SPAL cooling fan with manual switch
- Custom modified Street Triple Helibars
- Carbon fibre front fender (Triumph Street Triple)
- Airtech hugger (for CBR900RR)
- Shindy Daytona steering damper
- RC51 instrument cluster with carbon fibre cover
- Speedohealer
- Racecon Products quick-release red anodized fuel cap
- Powerbronze “double bubble” type iridium windscreen (cool blue)
- HRC-replica rear brake MC reservoir
- Maviryk Li-ion battery
- Cameleon automatic chain oiler
- Ducworks bar-end mirrors
- Mirror block-off plates
- Front parking light removed, gutted, drilled lens
- Powdercoated rearsets
- HRC 1/6 turn throttle tube
- Numerous Ti and Al bolts, nuts, screws,….
- Sargent seat
- Carbon engine case protectors
- No cut frame sliders
- Two Brothers aluminum exhaust hangers
- Protek slash-cut footpegs
- Kickstand switch removed
- aluminum quick-release gas tank hinge pin
- All Balls tapered roller steering bearings
- VFR800 regulator
- Durbahn carbon/fibreglass rad airscoops
Running gear
- PVM cast magnesium wheels (powdercoated red; rear is 6” wide)
- ceramic hybrid wheel bearings
- 520 pitch chain with Al rear sprocket (15/43 gearing)
- Red anodized Al angled tire valves
- EBC 320mm race rotors
- Braketech caliper relocation brackets
- F4i front calipers with Vesrah RJL pads
- F4i rear caliper
- Speedbleeders on all calipers
- Custom machined rear rotor (save 1 lb)
- Braided lines all around
- OEM Ducati (Monster 1100) Brembo MCs, Pazzo levers
- Vista-Cruise
- Driven D3 grips
- Michelin Power Pure tires (190/55 rear)
There really isn't too much left to do without either spending serious money or compromising its all-round goodness.
Dyno numbers (on new engine) are 121.8 hp and 76.6 lb-ft. Those will surely rise slightly as the engine breaks in. As for the weight, I haven't yet weighed it but I weigh parts as I remove or replace them and the wet weight should be right at 400 lbs (based on listed stock wet weight of about 480 lbs).
thanks for looking and for all those who helped me over the years
P.S. Don't take this to mean I am parting with it, it is with me to stay....
dave-sp2
Re: Mikstr's VTR
Post by dave-sp2 »
very nice!!!!!!!!!!!
Re: Mikstr's VTR
How's the weather out there now? Have you been out on the bike yet? Sorry you missed out on those carbon frame covers on E Bay. The muppets on there have been the source of much discussion recently. Take care.
Re: Mikstr's VTR
Definitely getting there, mate.....
:thumbdown: :thumbup:
Eclectic
Re: Mikstr's VTR
Post by Eclectic »
Very nice, sir.
Sent from my Desire HD using Tapatalk
Leewarne
Re: Mikstr's VTR
Post by Leewarne »
Hi, it that an SP1 speedometer?
Was it difficult to fit as it looks very cool on the firestorm.
Cheers Lee
Almost forgot, Sweet Ride!! :thumbup:
gilson
Re: Mikstr's VTR
Post by gilson »
I don't like it at all...... LIE!!!
Lovely job Mick.
No bike (yet).
Re: Mikstr's VTR
Micky, that is one hell of a bike you have there 8) 8)
You must be very pleased with the outcome of all your hard work over the years. Those figures and the amount of weight loss must make for some very interesting riding I'm sure :wink:
Thanks for the descent photo's, I really enjoyed going over them. The more I looked the more mods I could see, and those were only the visible ones :lol: I liked the transfer/decals on the side fairing panels saying "V Twin Inside" :D
Glad to hear you're not thinking about selling her after all the time, money, hard work and effort gone into this bike.
Cheers,
mik_str
Re: Mikstr's VTR
Post by mik_str »
Thanks for the kind words Chris :)
On the downside, my tech was not able to get the open airbox arrangement to work (may try again at some time in the future but dyno time costs money....). The torque curve is quite flat with no dips or peaks at all. The last remaining issue relates to the bike`s ability to handle rapid throttle input at low speeds. While not severe, it does tend to balk slightly, a situation I don`t really care for as the one thing I have rerally grown to like is the bike`s snappy response. MY thinking is that the lighter DJ slide springs are opening too quickly. I am looking at addressing the matter (with some fine-tuning) in the coming days.
Apart from that, she runs very well (and will only get better as it breaks in). The front brake too, is absolutely amazing, very powerful and progressive. I am a very happy Stormer :)
benny hedges
Re: Mikstr's VTR
Post by benny hedges »
the dj diaphragms springs will definately be the cause mik.
i had exactly the same issue with mine, making it way over-rich low to mid rpm.
i fitted a pair of new oem springs and it made a world of difference.
(took ages to arrive from honda san though)
tbh bud i think you'd prefer the bike if you put it back to standard.
if you want to swap any of your bling for standard parts just drop me a pm :D
mik_str
Re: Mikstr's VTR
Post by mik_str »
Thanks Ben, I am touched by the kindness (and selflessness) of your offer, lol
In regards to the slide springs, I have the OEM springs on hand and may eventually try those again. However, as those have a different rate and preload, slipping them back in would require a few adjustments (to pilots, fuel screws, needle,...) which I would rather not do if possible. The problem is not with the fueling being rich at any point in steady state operation (or in gentle throttle application either), but rather a hesitation whne the throttle is opened aggressively (easy to do with an HRC 1/6 turn throttle tube, he he). My theory is that the slides lift too quickly, opening up the intake area too quickly and causing the engine to bog momentarily. By slowing down the rate of slide movement, it should allow the slide opening to better match the engine`s ability to handle the increased venturi size (or area if you will).
I will (initially) be installing a set of modified OEM slides with one of the two lift holes filled (leaving only one open). This should, in theory, slow down the rate at which they open without affecting their equilibrium height (ie. the height at which they settle when the vacuum and spring rate fall into equilibrium).
It`s all theory for now but, as the physics supposedly supports my course of action, it should correct, or at the very least, improve, the problem.
benny hedges
Re: Mikstr's VTR
let us know how you get on with that mik....
when you think about it, if you run hi compression pistons, you also make higher vacuum which would affect the movement of the diaphragms.
this is why i think the dj kit is a bit haphazard.... sure it's easy to fit, but without dyno setup it's pure luck & flaw.
what pilots are you running btw>>> i'm using 50's atm with a bmc race filter and it seems bob on but i havent had it back on the dyno yet, was going to wait til ive done the pistons - and i didnt want to do that til i saw what tony's ran like with the pistons & cams lol, was worried about them meeting the valves!
Re: Mikstr's VTR
So little faith......
benny hedges
Re: Mikstr's VTR
tony.mon wrote:So little faith......
was more a case of seeing if yours smashed itself to pieces before i did mine!!!
come on admit it... you'd do the same if i bit the bullet first! :biggrin
still havent got a clue what the lift is on my cams though compared to std.
Re: Mikstr's VTR
mik_str wrote:Thanks for the kind words Chris :)
Interesting to hear about the slight balk from a rapid throttle response Micky. Knowing what you've been like in the past you'll will be sorting this out for sure, so you're completely happy with the results :wink:
The front brake sounds excellent too.
One thing I now see is you have the TPS adjusted to 430 ohms. Out of interest how did you come to this figure, and what difference does it make :?:
