occasional fault/missfire
Re: occasional fault/missfire
Cheers Benny, I'll keep that in mind when the time comes :thumbup:
Gerrit
Post by Gerrit »
The NGK caps come in a viety of options, straight L shaped
I got the L shaped option, but the "old" sheath will not fit.
I have been using it and there was no muck build up.
Gerrit
13yearsVTRrider
Post by 13yearsVTRrider »
* Report this post
* Reply with quote
New postby Gerrit » Sat Feb 12, 2011 8:14 pm
Replace the Spark Plug caps
"I was battling with a intermittent misfire for months, and eventually, I found the problem in the Spark Plug Caps.
There is a resistor in the cap, that fails, and causes all the drama.
I replaced mine with NGK caps, and the bike has never been better.
Have a look at the photo below...if you remove the rubber sheath, you can unscrew the cap, to reveal the resistor and the spring that conducts the current down to the plug.
The spring was corroded and the resistor was dead.
me thinks this is a fix to many peoples problems."
The problem with the standard plug caps is removing them after say 8000 miles when you want to replace the plugs. I used a pair of pliers in desperation and in so doing I split the rubber - I didn't notice this at the time - however I think some water does get in especially after pressure washing - it misfires for a short time after until it warms up. I'd be inclined to fit new standard caps/leads just to keep the seals as I ride in all weather, with a dab of grease -silicon grease possibly - applied to the socket where the plug connects - this might make it easier to remove the cap when required.
benny hedges
Post by benny hedges »
methinks the resistor is there for a reason - it's part of the circuit.
taking it out will no doubt give a fatter spark but could possible damage the coil as that is then the only resistance in the circuit.
like you cant short out a mains wire, but you can if you put a light bulb between the wires, if you get what i mean....
yorkylancs
Post by yorkylancs »
Benny lad,when you say "check for rust where the coil bolts to the frame" whats this mean then? one of my coils has never been bolted to the frame.Just wondering.
