SWAGGER wrote:sirch345 wrote: ..... I had LED indicators made by Motrax on my bike at one point, the photo's below are all I have now showing them, so not brilliant. They are the long stem type ....
Chris,
for the avoidance of doubt .... the long Motrax units bolt straight onto the inner panel ... right? BTW I think they look pretty good in your pics. Were you not happy with them?
Yes, the Motrax (long stem) indicators bolted straight onto the inner panel. I can't remember if I added any washers to make them stick out that little bit more, but if I did that was all that was required, well apart from a different flasher relay that is. With the standard flasher unit the LED indicators flash too fast.
The problem with the standard front indicators is, if your bike ends up falling on it's side they will smash up the inner panel. I'm not sure how much protection they would get with your R & G crash protectors.
I had a good deal on these (see photo below) and are available from Hein Gericke (you can see them on their online catologue, page 302). What I prefer about these is, they can be seen from the side as well as the front when in use.
HTH,
![Image](http://i55.tinypic.com/frr7p.jpg)
