Hey folks,
I'm in need of a decent set of VFR800fi front discs.
Bought a project '99 VFR that has a very skinny set on at present... If any of you have some hiding in the store cupboards, give me a shout!
Cheers,
Matt.
VFR800fi Front Discs
Moderator: VTRDark
Re: VFR800fi Front Discs
Do you know if these are the same size as any other Hondas CBRs etc? I'm sure I have a pair of early 900s somewhere if you know the sizes you need.
Don't hassle me
I'll get there at some time
Good question...
From a google, I've found the following:
Should be the same as:
VFR400R (NC30) 1989-93
CBR600 F4 1999-00
CBR 900RR 1992-94
XL1000V Varadero 1999-02
GL1500 F6C Valkyrie 1997-05
GL1800 Goldwing ABS 2001-11
Cheers!
CBR600 F4 1999-00
CBR 900RR 1992-94
Cheers!
I'm not up the road till Sunday but I will measure up what's hanging up.
Don't hassle me
Been out and had a look. The ones I have are for a 98 blade by the sizes. 330mm dia 110mm bolt spacing. Still got 4.5mm meat on them. Think the ones you are looking for are smaller than these. I may be wrong.
Don't hassle me
Hey - thanks for checking! Apologies for the delay, it's been a bit hectic over here.grumpyfrog wrote: ↑Sun Dec 08, 2019 7:53 pm Been out and had a look. The ones I have are for a 98 blade by the sizes. 330mm dia 110mm bolt spacing. Still got 4.5mm meat on them. Think the ones you are looking for are smaller than these. I may be wrong.
Still on the lookout for a decent set, will keep my eyes peeled.
