I have bought some universal bar ends that fit by expanding a rubber inside the bar. How do I remove the fitting that's already in there that the Honda bar ends bolt to?
Any advice appreciated - I don't want to damage anything trying to force them out!
Fitting Bar Ends
I did try that, but because the original is 'keyed' it only sits on half the face. Seems pretty secure and looks ok though, so I'll leave it like that.alan wrote:Rob use the bolt out of your original bar end to bolt your new bar end dont use the rubber.no need to take the centre thingy out it will tighten up ok
I did this on my old bars without any probs..
Cheers,
Rob.
- Stormin Ben
Re: Fitting Bar Ends
Rob wrote:I have bought some universal bar ends that fit by expanding a rubber inside the bar. How do I remove the fitting that's already in there that the Honda bar ends bolt to?
Rob,
The Honda fitting is held in by a couple of spring loaded pegs that are about half way under the grips
You need to peel them back and you'll see the lugs which you can press in and the whole lot then just pulls out
Interestingly I found the tingles a lot LESS after removing them -weird eh??
But its not a very good one!
