crack in frame
brett
crack in frame
Post by brett »
: :cry: has anybody found a small crack in the righthand upper frame tube where it joins the headstock had it to a professional welding inspector whitch tells me i have a flaw in the weld its booked in to honda tomorrow for :an inspection fingers crossed
stormy 1
Post by stormy 1 »
No mate mines fine 8O ,sorry to hear about yours :!: .What year is it as it could be a possible fault to look out for,but with any luck its a one off :!: .Still that doesnt help you hope its not as bad as first thought :roll: .
noise polution?,you should see my MPG!!!
VTR1000fw,scorpian cans,dynojet and K&N all wrapped up in HRC colours.I need a HRC avatar!.
996superhawk
Post by 996superhawk »
Here in the state the GL1800 goldwings are having a problem with frames cracking
stormy 1
Post by stormy 1 »
That will be the 30+stone blokes that ride them :wink:
Stormtrooper
Post by Stormtrooper »
i think that if they are being hoisted up on monos, this will not help as the
jarring effect when the bike comes back down can cause cracking
