pops from under tank any halp please
i guys i am new to the firestorm and v twins as i also have a 1200 bandit. i have noticed that when i am in low gears in traffic and stay in the same gear eg 2nd at between 2 and 3 thousand revs i get a weird popping noise from under the tank i think it may be from the carbs maybe front but i am not 100% sure the bike had 7000 miles on it. i have checked the carb balancing and its fine, its now begining to bug me does anybody have any ideas ? it runs perfect when normal riding.
get your carbs balanced....especially if you've fitted new cans and a K&n type filter. mine popped so hard at times it nearly blew the seat off. once the carbs were balanced it stopped
I AM THE STRANGE MAN YOUR MOTHER WARNED YOU ABOUT......
Have a sweetie and stop crying........
[Werthers Original...they never get rid of the taste]
Wow i'm glad i was looking through here and i found this post. I've been stressing out for ages trying to figure out what is wrong with my engine, thinking it was getting some detonation or something. I was about to start on checking the fuel delivery cause i already got it tuned and that didn't help. I'm so happy to hear it's normal!
-MickieB
it could be the cold weather as the carbs are prone to icing and the pilot jets get affected. Bike leans off and then starts back firing. Or if you have fitted cans or k&N then the pilotn air screw mixture may be too lean and need backing off slightly. Never had this (for long apart from in the winter when coming of a long motorway blat) longterm and have got rid of a it by setting the carbs up.
