leather boys
leather boys
got me self a one piece suit, harder to get into than a virgins knickers, got stuck half way, arms pinned by sleeves, wife nearly wet herself laughing.
so is there a trick to getting in and out of a one-piece.
- Stormin Ben
yeah......its right size, little tight on tum but once on very comfortable.
Get one arm in then other up to elbow but buggered if I can get it all the way up. ( Iggy dont you dare ) Suppose it will get easy with practice, just hope I don't need a pee in a hurry.
Do think it makes me look slimmer
did you unzip it first?
anyhoo, try putting both legs on and pulling it up so its like normal pants with the top half loose at your waist. Then you can lie flat on the floor on your back, with the top half under you flat, then put one arm in at a time.
You should be able to put it on normally once it's freed up a little.
