tight spot on rear wheel
stu9000
Post by stu9000 »
before you say it, its not the chain (i think, anyway).
was lubing the chain today and hand rolled the rear wheel to check it.
Found a sort of dry sounding tight spot.
The wheel still turns pretty freely but...
... is it the bearings?
MOT due soon and i would not mind knowing what the problem is before it goes in
red is the fastest colour;)
Squiffythewombat
Post by Squiffythewombat »
does the wheel have any play it in? ie: can u wiggle it?
Squiffy_The_Wombat
mik_str
Post by mik_str »
Well, logically it is one of three things:
1) chain and sprockets
- bent sprocket(s)
- worn and binding chain
2) brakes
- bent rotor causes binding
- stuck caliper (combined with above)
3) wheel bearings
- tough to isolate so long as chain and brake are still attached
- check for play in wheel, listen for noisy bearings
Best of luck :)
Mikstr
alan
tight spot
Post by alan »
Have you checked your adjusters to see if they are equal?
I know they are not that accurate but they will give you a rough idea if the wheel is in line or not.
Try raming a screwdriver in between the pads and opening them up so they don't touch the disc.
If it turns freely check out the disc/calipers
If not stick a dab of grease on the chain and turn the wheel and see if goes stiff when the chain reaches the same place everytime.
BTW a stiff chain or worn sprockets is not a MOT failure
lastly if you grab the wheel top and bottom and rock the wheel side to side you should have no movement or clicking noises. That would be a worn bearing
stu9000
thanks guys
Post by stu9000 »
Ok,,,
Bombed it down to Brighton today, gorgeous afternoon of A24 fast sweepers. But there is definitely something not right there. At slow speeds I can feel it, a sort of rythmic rough spot. The chain has done about 10000 miles and Im sort of expecting to need to change it, but Ive lubed it up till the bikes splattered with gunk. When i hand turn the wheel on the paddock stand there is no chain related stiff points. The chain links are not seized.
The reason im even looking for a problem in the first place is I seem to have excessive vibration through my left leg, enough to make my joints sore on a 50m run. Am i getting old or should I just stop whining and take the bike to the garage???
There is no sideways play in the rear wheel.
The sprockets look fine to me.
It might not even be the rear wheel. The vibration seems to come from the front sprocket area.
Its not that bad, but at the same time Im not sure Id find a weekend away that comfortable at the moment.
MOTs due but Ive changed jobs and am looking for a new garage. Anyone recommend anywhere in the Byfleet Woking area?
xxxrated
Post by xxxrated »
if youve done that amount of mileage on the chain get than changed first along with the sprockets as there well overdue. being as they need doing anyway if they dont sort the problem out at least you havent wasted any cash as such
stu9000
Makes sense
Post by stu9000 »
Yeah, I figured it made sense to change the chain. New tyres needed too. And a tune and balance is overdue.
As a general question, what things wear out on the VTR?
29000 miles on the clock.
Cam chains changed at 14000 miles.
stu9000
Post by stu9000 »
I think this problem with the vibration has been there a while,
but its definitely getting worse.
Just had it up on the paddock stand to check a few things.
There is no play in the wheel laterally.
The wheel is on straight.
I dont think the disk is warped.
But when I turn the wheel by hand it does have tight spots. If I push it round
lightly with two fingers there is a pronounced stopping point, although its pretty easy to push on through. There are a couple of other lesser stiff points as i turn the wheel right around.
My guess is that its the rear wheel bearings.
The bike is coming up to 30000 miles.
But I wonder if the problem could be at the sprocket end?
But probably a bearing rather than chain and sprocket dont you think?
One thing, I did T bone a white van that jumped out on me a few months back. Clearly his fault and the bike got put right, but is it possible the wheel could have developed a problem over time? Seems a bit late on.
And how much chould I add on for a fix.
MOT due and new tyres, chain and sprocket already on the list.
Anyone know anywhere good in the Wimbledon to Woking, Byfleet area?
Cmon guys, solve my problems for me and make life easy 8O 8O :lol: :lol: :roll:
Stormin Ben
Post by Stormin Ben »
Easy to check wheel bearings
Remove rear wheel, stick finger in bearing and rotate
If its gone you'll feel it as a grindy feeling
Also, don't forget to check the one in the sprocket carrier
TBH my guess would be a couple of tight links on the chain.
Rotate forwards til you feel the tight spot, then rotate backwards a bity til the suspect link emerges from the gloom.
Check to see if it feels stiffer than the rest
But its not a very good one!
stu9000
Post by stu9000 »
cheers ben
u da man 8)
Skatrekker
Post by Skatrekker »
Try FWR at Brixton for the Chain + Tyres, website is unsuprisingly http://www.fwr.co.uk. They do fitting,servicing + all sorts and some very good deals on tyres
