Case halves
pmcq
Case halves
Post by pmcq »
Hey guys,
Maybe this is a stupid question, but when putting the engine case halves together using the gasket sealer, do I have to put it back together as soon as possible while the sealer is wet or is it ok to let it dry a bit first and then bolt down?
eddvtr1000
Post by eddvtr1000 »
if its the red jam type you should be ok for a while itll only go off in the air tight bit actually in the joint, any over spill will either just fall off or go off with heat. i forget the loctite number?
4 cyl = 2ltr , 2 cyl = 1ltr it's all relative.
jurgen
Post by jurgen »
I've used the blue stuff before...should let it go slightly tacky then put the 2 bits together.
Finally when it drives turns to a rubber. Also used the black stuff....horrible it is. Once you've put it on you have to put together straight away. Dries like tar and is a nightmare to get off your hands. Best to wear rubber gloves.
Jurgs
