Fitting a speed cam detector - i need to connect to a live switched feed (ie on when ignition is on and off when ig is off). The wiring is close to the fuse box - which would be a good wire to tap off?
the bike came with an led tail light with built in indicators. I put a meter on what I thought was the live, yhis apeared live all the time???? (even with the ignition off???) So looking for a definate live on/off
I took a live feed off the switched side of the ignition key from the back of the speedo for my heated grips and they are fine. I'll see if I can have alook tomorrow and tell you which wire it is.
