Speedo!
Speedo!
Hey All,
I just replaced my black speedo face for a nice white one to match the rev counter and temp gauge - I had to paint the needle coz it was white so I sprayed all 3 needles a nice red colour. I had to remove them to do this. On putting them back I think my readings are incorrect. Its not a case of putting them back on at zero as I found out, becuase once the ignition is tuned on they jump slightly. I have a feeling i need to put them at 6 o'clock on the face and then clip them over the small arm that holds them a zero but just wondering if anyone else has done this?
Cheers!
pmcq
Cheers!
pmcq
- Pete.L
I did this a few years back after a smash i had to rebuild the clocks.Its not a case of putting them back on at zero as I found out, becuase once the ignition is tuned on they jump slightly. I have a feeling i need to put them at 6 o'clock on the face and then clip them over the small arm that holds them a zero but just wondering if anyone else has done this?
All I did to recalibrate the clocks was have a friend drive at a constant 70MPH and I drove along the side of him and when he signaled he was doing 70 I saw my clocks were only reading 62. So when I got back I just added 8MPH to the needles from a static point and job done
I'm pleased and I would imagine VTRgirl will be also, to see you've now stopped your bike spinningpmcq wrote:Cheers Pete.
VTRGirl - yea I know - it was an experiment - I took a load of pics of the pic and shrunk them - had to go really really low quality coz there is a size limit on the pics... Will have to come up with something new now! :-)
PS Shouldn't think handling has improved much with those new tyres
