Melted battery
Buddy
Melted battery
Post by Buddy »
I was touring france and spain in the summer, doin around 90mph constant on the motorway, when my bike just suddenly died. I got off and i could smell burning plastic. Eventually i lifted the seat to find the battery had swelled up and had even cracked the battery holder. So i bought a new battery and checked it every 60 mile or so, but the same thing started happening again, so after some advice i disconnected the alternator. this cured it and got me home but obviously i need my alternator connected. Can anyone tell me what the problem is. do i need a new alternator or what.[/b]
It sounds like the voltage regulator rectifier needs replacing :!:
Druid
Post by Druid »
Yep, regulator/rectifier is almost certainly u/s, and is allowing the alternator to overcharge the battery - leading to a melted battery. Disconnecting the alternator will obviously prevent this happening again, but it brings its own problems ;)
You will probably need to buy another battery, the one you bought is most likely damaged already.
Buy a replacement reg/rec from Electrex. They are better than the OE ones, and a bit cheaper too.
If you have a multimeter and want to check out your charging system first there is a good fault finding chart here. Basically the voltage across the battery teminals should be between 13v at idle, rising to 14.5v as you rev it. Any more than this indicates a faulty reg/rec.
“I don’t want to live in a society where some do gooder thinks my safety is more important than my freedom” – Richard Rutan
Buddy
Post by Buddy »
Cheers guys ........replaced the rectifier and battery ... job done
Paul :D
VTRgirl
Post by VTRgirl »
Flamin' wreck you later rectum friers... :evil:
