Bent my rear brake lever. Does anyone know of an aftermarket one I can purchase and where? Honda dealer wants $60US for a new one.
Thanks,
Scott
rear brake lever
- Stormin Ben
- Scott Malcolm
It's pretty bad. I thought about trying to bend it back too, but I figured it would break. What did you use to heat it up? Maybe I'll give it a try. I really don't have the clams for a new one. The end of the lever (foot part) is bent almost straight with the arm, so instead of it being at a 90 degree angle, it hooks right around so it looks like a tight fishhook.
- Stormin Ben
Anything really, if you've got a blow torch thats great but I just use the gas ring on the cooker.
Top tip though, get some thick gloves!!
And keep it hot!!
I had the same amount of bend and just heated it, bent it a bit, heated it some more, bent it etc until it was where I wanted it
And if the worst happens and it does snap you could always drill a hole near the end and put a bold through!! Did this on my old H100 in my student days (long gone now, sniff sniff)
Good luck
Ben
And keep it hot!!
Good luck
Ben
- Scott Malcolm
- Scott Malcolm
Follow up
Just to follow up on this. I was able to bend it back successfully. I used a propane torch to heat it up real good, then would bend it a little, heat it, bend, heat it, bend it, etc. I was surprised how good it worked. I really had to heave-ho the thing and I kept expecting it to snap off, but it did not.
Saved my self something like $60
Scott
Scott
