removing the old uns
Tell me,when you remove the old cct,do you need to "wind in" the plunger thing first,or just undo the 2 allen screws and whip it out?(I know about the tdc,on compression stroke) thx in advance
Very funny Scotty...now beam down my clothes
Re: removing the old uns
Yes you are suppose to wind in the plunger thing first as you put it. You will see the new ones are fully wound in. It just makes for easier removing/fitting of CCTs.buzzard wrote:Tell me,when you remove the old cct,do you need to "wind in" the plunger thing first,or just undo the 2 allen screws and whip it out?(I know about the tdc,on compression stroke) thx in advance
PS.Quote (I know about the tdc,on compression stroke)
AS LONG AS YOU DO KNOW, YOU SHOULD BE ALRIGHT
