does VTR1000 2001 has lambda probe?
Hi everyone! just a small question, a friend of mine told me that his R6 has a lambda probe on his exhaust , but I'm seeing that my vtr2001 doesn't or I couldn't found it.
Could someone confirm me that vtr2001 doesn't have lambda probe?
Cheers!
EDIT: just to mention that my bike DO has FI (fuel injection) But I'm not seeing a lambda probe anywhere.
Cheers!
Re: does VTR1000 2001 has lambda probe?
Not as standard. They're only needed with fuel injection systems.
But I added two lambda wideband sensors in the downpipes and connected a display to show real-time air/fuel stoichiometric ratios when riding, to aid carb setup, on my tuned firestorm.
It saved the cost of repeated Dyno runs whenever I changed anything.
One of your good mod's that Tonytony.mon wrote: ↑Wed May 15, 2024 4:16 pm Not as standard. They're only needed with fuel injection systems.
The fuel-injected Varadero engines ( which are based on the same engine) will possibly have one, but I don't know for sure.
Tks guys, but just to be clear, my bike do has fuel inyection system, it's not carburated at all.
How this works without lambda probe?
Do you have an SP1 or SP2?
Has somebody fitted injection to the bike because no firestorm came with it as standard?
More likely to be an SP.
It's an SP1 RC51 I have just checked
https://vtr1000.org/phpBB3/viewtopic.php?t=46064
I see said the blind man that makes sense
I've no idea whether a standard exhaust on an SP has a lambda sensor; mine was non-standard.
