Battery/ fuses
rollingthunderx2
Battery/ fuses
Post by rollingthunderx2 »
I recently fitted a bigger battery and unfortunately the negatine screw wasnt into the stupid square nut.
So the bike cut out ..luckily 100m from my house.
Unfortunately I dropped it as it cut out then restarted on the very rough track to my housr..as it was neg camber I couldnt pick it up.
When we did I couldnt get the battery out to charge it.
The higher battery was hitting the fuse box. And was a very tight fit in the battery holder.
Eventually I put cable ties through the terminals and pulled it out.
Reinstalled with a bid cable tie around it.
My question is..can you remove the fuse box?
It serms to be clipped into the undertray?9
Re: Battery/ fuses
Yes it unclips. There's a tab at the top. Push to the front & it lifts out.
I put a fabric strap around the battery leave it in place use it to pull the battery out.
rollingthunderx2
Re: Battery/ fuses
Thanks Mac..ive put a big canle tie atound the battery now. Ill have a look at the fixing tomorrow. The big battery is tight but what a difference to starting.
I have a longer neg lead Im going to fit at the weekend.
